Visualize Cisco ACI Networks
With NetBrain, you can quickly visualize and understand a Cisco ACI fabric from the following aspects:
- The objects in your Cisco ACI Fabric, such as ACI PODs, IPN, ISN, and their topology.
- The detailed information about a node, such as properties, chassis, interfaces, and fabric extenders.
- The overlay design over a Cisco ACI Fabric, such as logical layer dependency and connectivity inside or outside an application.
- More data information by applying data views.
User Flow
Prerequisites: Make sure the discovery and benchmark of your ACI network have been completed. |
The general flow of visualizing an ACI network in the NetBrain system is as follows:
- View your ACI network tree.
NetBrain provides three views to help you better understand your ACI network:
- Network Centric View:
- Application Centric View:
For more information about context maps, refer to Supported Context Maps of ACI Nodes.
