View ACI Network by Application Deployment
The application-centric view allows you to see different tenants and the applications deployed under each. The ACI data model is organized as Tenant > Application Profile > EPG > Endpoint. In the Network pane, you can view the applications deployed over an ACI Fabric and the application structure.
- Select Network in the left pane of your NetBrain desktop.
- In the Network pane, select Cisco ACI in the Category field.
- In the View field, select Application Centric View.
- Expand a tenant node to view all applications in the tenant.
- Click an application node, and then select a context map type to view the corresponding structure of the application.
- Logical Structure — provides an overview of the logical relationships between endpoint groups and their contracts. In addition, NetBrain can visualize Service Graph (its icon has a slight difference from that of Contract).
- Underlay Map — provides the context of how the application is deployed on these nodes.
Tip: For more context maps supported under the Application Centric View, see Context Maps for details. |
