Supported Functions and Operators
You can view the following details:
The following functions are supported:
Function Name Example Description
ToString string ToString(number or datetime or boolean $input) Converts a number, a datetime or a boolean to string format.
Duration number Duration (datetime $startDate, datetime $endDate, string $unit) Calculate the time difference between the start date and end date. The output is calculated by the unit and given in number format. Supported unit includes week, day, hour and minute.
Year number Year (datetime $date) Subtract the year from a date
Month number Month (datetime $date) Subtract the month from a date, a number between 1(January) and 12(December)
Day number Day (datetime $date) Subtract the day from a date, a number between 1 and 31
Hour number Hour (datetime $date) Subtract the hour from a date, a number between 0 and 23
WeekofYear number WeekofYear (datetime $date) Subtract the week from a date, a number between 0 and 53
Now datetime Now () Returns the current time in datetime format
Ceil number Ceil (number $input) Returns the smallest integer that is greater or equal to the given number.
Floor number Floor (number $input) Returns the largest integer that is smaller or equal to the given number.
IF number or string or datatime IF (logical expression $expression, $value_if_true, $value_if_false) First verifies if an expression is true or false, then returns a given value based on the verification result. The data type of variable $value_if_true and $value_if_false should be same.
The following mathematical operators are supported:
Operator Example Description
number A + number B
string A + string B
Add two numbers and return the sum in number format, or combines string A and string B and returns the result in string format
number A - number B
Subtract two numbers and return the difference in number format
* number A * number B Multiply two numbers and return the result in number format
/ number A / number B Divide two numbers and return the result in number format
^ number A ^ number B Raises number A to the power of number B and returns the result in number format
() (number A + number B) * number C The expressions within the parenthesis are evaluated first
The following logical operators are supported:
number A < number B
datatime A < datatime B
Evaluate if number A is smaller than number B, or datetime A is smaller than datetime B and returns the result in boolean format.
number A > number B
datatime A > datatime B
Evaluate if number A is greater than number B, , or datetime A is greater than datetime B and returns the result in boolean format.
number A <= number B
datatime A <= datatime B
Evaluate if number A is smaller than or equal to number B, or datetime A is smaller than or equal to datetime B and returns the result in boolean format.
number A >= number B
datatime A >= datatime B
Evaluate if number A is greater than or equal to number B, or datetime A is greater than or equal to datetime B and returns the result in boolean format.
= or ==
number A = number B
number A == number B
string A = string B
string A == string B
boolean A = boolean B
boolean A == boolean B
datatime A = datatime B
datatime A == datatime B
Evaluate if two numbers, two strings, two booleans or two datetimes are equal returns the result in boolean format. The operator = is equal to operator ==
number A != number B
 string A != string B
boolean A != boolean B
datatime A != datatime B
Evaluate if two numbers, two strings, two Booleans, or two datetimes are not equal returns the result in boolean format.
&& or AND
boolean A && boolean B
boolean A AND boolean B
Evaluate if two values or expressions are both true and return the result in boolean format. The operator && is an alternative to the logical function AND.
|| or OR
boolean A || boolean B
boolean A OR boolean B
Evaluate if at least one of multiple values or expressions is true and returns the result in boolean format. The operator || is an alternative to the logical function OR.
! or NOT
! boolean A
NOT boolean A
Returns the opposite value of boolean A. The operator ! is equal to logical function NOT.
