Execute CLI command
Executing commands on devices with Smart CLI is a basic but very critical function of this tool. Many follow-up operations are performed based on the outputs of executing commands. For example, you can Compare with Historical Data to detect Changes. To get data on a regular basis, you can also Schedule Command Execution and Automate Command Execution through Runbook.
