Elements of a Qapp
The fundamental element of a Qapp is called a node. Each node contains specific attributes and connects logically.
Example: Nodes in a Qapp Editor
Nodes in the Qapp Editor
The Qapp Editor has two types of tabs:
  • Execution Flow tab — define the execution sequence of the nodes within a Qapp, as well as the relations or conditions among the nodes.
  • Canvas tab — contain an internal workflow composed of multiple subnodes as follows.
Context Menu of Qapp Editor
The context menu in the Qapp Editor is as follows:
IconDescription
Save the Qapp.
Save as another Qapp.
Run the Qapp.
More operations, such as customizing functions and locking the Qapp.
Built-in Variables in Qapp
The following table introduces the system built-in variables in a Qapp.
Variable NameDescription
$_device
A global PyDevice object representing the device on which the Qapp is running.
It is a simple PyDevice object and not an array of PyDevice objects. The Qapp automatically loops through each of the selected devices.
$_device_queueA variable representing the device queue table that the Qapp loops through.
$_commandThe command on which the output is based.
For more built-in variables, refer to the Global Data Repository (GDR).
