Operating on Qapp Nodes
Extending a Node
- Point to a node, click the
icon at the upper-right corner of the node icon. A dialog will prompt to indicate the available nodes to extend. - Select the next node from the list, and you can see the node description to get to know what the node is used for.
- Click Extend.
Deleting a Node
Use one of the following ways to delete a node:
- Click the node and press the Delete key on your keyboard.
- Right-click the node and select Delete from the drop-down menu.
Note: The Delete option is only available for both Device and Command nodes.
Connecting Nodes
To connect two nodes manually, do the following:
- Point to the right side of the first node icon. The pointer turns into a hand.
- Press and hold your left mouse button to draw a line, and then release it when pointing to the second node icon. The two nodes will be connected by a directional line.
