Qapp Center
Qapp Center
Qapp Center is a self-contained manager that provides you with a comprehensive view of all accessible Qapp files.
- Built-in Qapps — contains the pre-installed Qapps. This category is accessible to all users but can only be modified by system administrators.
- Shared Qapps in Tenant — contains Qapp files that are accessible to all users in this tenant.
- My Qapps — contains Qapp files that are only accessible to yourself. You can find your private Qapps in all accessible domains under one tenant.
Working with Qapp Center
- Click the start menu
, go to Map-Based Automation section and then select Qapp Center. - Point to a Qapp file and click the
icon to preview it.
Note: You can also right-click a Qapp and select Run it as a Runbook node.
