Define Report Columns
By drag-and-drop report fields from the Report Tree to Report Columns, you can define the columns of the report. You can also adjust the column orders by moving the report fields up and down in the Report Columns.
Example: Create Report to View Intent Results
Goal: Create a Report to view Intent results by Intent name, execution time, and Intent Status Code.
Drag and drop the following fields from Report Field Tree to Report Columns:
- Intent name
- Execution Time
- Intent Status Code Summary
- Intent Alert status Code Count.
- Intent Success Status Code Count.
