Define Aggregation
You can define Aggregation to narrow down the report input quickly.
 Report ObjectsAggregation
1
Primary/Additional Object
Intent Result
Last Intent Results
First Intent Results
2
Intent Device Result
Last Intent Device Results
First Intent Device Results
3
Device Change Analysis
Last Change Result
First Change Result
4
Application Path Historical Result
Last Path Historical Results
First Path Historical Results
Example: Report input contains the last execution results from the past 7 days of the intent Check BGP Neighbor.
Follow the steps to define the report input:
  1. Select the Intent Name as Check BGP Neighbor.
  2. Drag and drop the Execution Time to the report input and define it as Last 7 days.
  3. Aggregation: Select Last Intent Result.
