Include Follow-up Intents
You can decide whether the execution results of follow-up intents will be included in the report input when Intent Result or Intent Device Result is selected as the Primary Object in a report.
Example: Users select NI2 as report input.
NI2 Intent Executions Report Input
2023-5-10
NI1(Home NI) --(Trigger)--> NI2 --(Trigger) ---> NI3
2023-5-11
NI2(Home NI) ---(Trigger)----> NI3
 2023-5-12
NI2(Home NI)
2023-5-13
 NI1(Home NI) --(Trigger)---> NI2
Check the Use selected Intents only option:
Only the execution results for the selected intents will be included in the report, regardless of whether the selected intents are home or follow-up intents.
Example: Only the NI2 execution results will be included:
2023-5-10   NI1 ->
NI2 -> NI3
2023-5-11
NI2 -> NI3
2023-5-12
NI2
2023-5-13   NI1 ->
NI2
Uncheck the Use selected Intents only option:
The execution results will include the selected intents when it is a home intent, and its follow-up intents will also be included in the report.
Example: The NI2 execution results when it’s a home intent and the triggered follow-up intents will be included:
2023-5-10   NI1 -> NI2 -> NI3
2023-5-11
NI2 -> NI3
2023-5-12
NI2
2023-5-13   NI1 -> NI2
