Data Tables
In the Device Details pane, you can perform the following actions:
- Browse Data Tables in Device Details Pane
- Retrieve Data Tables from the Live Network
- Compare Historical Data Tables
Data Table Supportability
Data Table
IPv4 Supportability
IPv6 Supportability
1
Route Table
Yes
Only support data retrieval via CLI
2
ARP Table
Yes |
No
3
MAC Table
Yes
No
4
NDP Table
Yes
5
NCT Table
Yes
Browsing Data Tables in Device Details Pane
- In the Device Details pane, select the Data Tables tab. Only the available data tables for the target device are listed.
Click your interested table type to browse data in detail.
Retrieving Data Tables from the Live Network
In the Device Detail pane, click
to open the pop-up window.
Click
to retrieve live configuration.
You could save the newly retrieved data table to the current baseline by clicking the icon
To review the original text data rather than in the table view, click the icon
Tip: To save the data table to the current baseline, close the window and open it again to enable the icon .
Comparing Historical Data Tables
Click
in the Device Details pane to open the Compare window for Data Table.
- You can select data tables from different times to compare. Exporting the comparison result is also available.
