Visualize VMware NSX-T Networks
VMware NSX is the network virtualization platform for the Software-Defined Data Center (SDDC), which delivers networking and security entirely in software, abstracted from the underlying physical infrastructure. NetBrain can discover the networks based on VMware NSX-T and visualize the NSX-T networks on dynamic maps.
Example: A Visualized L2 Topology Map of Logical Components under one NSX-T instance.
User Flow
Information Prerequisites: Make sure the discovery and benchmark of your NSX-T network have been completed.
The general flow of visualizing an NSX-T network in the NetBrain system is as follows:
  1. View your NSX-T network and components.
  2. Calculate Path Across NSX-T Network.
For more information about context maps, refer to Supported Context Maps of NSX-T Nodes.
