The following table outlines the available context maps of each NSX-T node.
Node
| Context Maps |
| NSX-T Virtual Distributed Switch | Two context maps are supported for this node: - Layer 2 Neighbors displays the Layer 2 topology to its connected Devices.
- Layer 3 Neighbors displays the Layer 3 topology to its connected Devices.
NSX-T Manager
NSX-T Tier-0 Gateway
NSX-T Tier-1 Gateway
NSX-T Segment
