About Path Results and Path Details Pane
After the path is calculated, you can use thPath Result and Path Details panes to review key information about the calculation.
Use these panes to:
  • Verify whether the path was calculated successfully.
    Check for success status and any related alerts.
  • Understand the path logic.
    View how the path was determined, including hop-by-hop routing.
  • Access the Path log for additional details.
    Review logs to get data related to the calculation process, which can help with troubleshooting.
