View Path Note Summary
The path Note helps you view and manage all notes associated with a path. It provides a quick preview of each note’s content.
You can select a note to open its full definition.
Notes for all devices along the path are included, even for hop devices that are not currently visible, such as those in load-balancing (LB) branches.
