Test Parser
Use the Test Parser feature to verify that the parser functions correctly, not only on the current device but also on other devices, before applying it in automation features such as Intent, Intent Template, Preventive Automation, Runbook CLI nodes, and more. This helps improve the success rate of these automation tasks.
After testing, review the results and logs to identify any gaps in the parser definition and make the necessary corrections.
Use Flow
- Specify testing devices: which devices to be tested.
- Specify data source and retrieve data: where the data for parsing comes from.
- Run the test and view the results.
If any error occurs in the test results, resolve the errors and test again.
