Global Search IntelliSense
Global Search is the start point for you to find any domain data. After entering more than 2 characters, the intellisense will display the data matching the characters. The search history is also listed.
IntelliSense Detail
When you enter a keyword, the IntelliSense will provide the corresponding device, interface, device type, interface status and so on. The displayed information varies depending on the type of entered content. Here is an example when an IP is matched.
The search scope is as follows:
IP
- Management IP
- Interface IP
- Virtual IP
- One IP Table
Hostname
- Hostname
- DNS Name
- Path Name/Application Name
Some examples of IntelliSense are as follows:
Note: When you click the search box, if there is a historical search record, it will be displayed. Otherwise, the IntelliSense will only be displayed when the input content exceeds 2 characters. |
Enter Hostname:
Note: Hover over a matched device entry, and you can click Map to draw the device on a map. -
Enter Map Name. The map name, page summary, editor, and last updated time are displayed.
If the input item matches Internet Cloud or MPLS cloud, you can distinguish them by the icon. Here is an example when the Internet Cloud is matched.
If the entered IP is an IP:
- If the entered IP matches a device, and this device belongs to an HA group:
- If the entered DNS matches multiple items, the device corresponding to the DNS will be listed separately:
- If the input content is in IPv6 format, the corresponding device interface information will also be listed:
The matched items can be categorized as follows:
Input Item
Matched Item
Displayed Information
Supported Operation
IP
Device Interface IP
Interface IP
Device Name
Interface Name
Vendor module
Site
HSRP/VRRP/GLBP Virtual IP
Virtual IP
Virtual IP Tag
Tech Protocol
Real IP summary
Real IP
Real IP Device Name
Real IP Device interface Name
Real IP Device Vendor module
Real IP Device Site
Internet Cloud
IP Address
Cloud Type
Connected Switch Port
MPLS Cloud
IP Address
Cloud Type
Endsystem
IP Address
Device Name
Unknown Endsystem
IP Address
DNS Name
Unknown IP
IP Address
HA Group
HA tag
HA interface IP
Device Name
Interface Name
Vendor Module
Site
Duplicate IP
IP Address
Duplicate IP summary
Keyword
Device Name
Device Name
Type
Vendor module
Site
Interface IP
DNS Name
DNS Name
IP address
Internet Cloud
Cloud Name
Cloud Type
MPLS Cloud
Cloud Name
Cloud Type
Endsystem
Device Name
MAC Device Name
Device Name
DNS Name
Application Name
Path Name
Path Source Destination Protocol
Path Name
Application name
Latest result time
Map Name
Map Name Page Name Editor Last Updated |
Map/Select Action Detail
In IntelliSense, each item has a Map button. Some examples of displaying the Map button are as follows:
Search by virtual IP:
Search by host:
Search by duplicate IP:
Depending on the device type, the content displayed after clicking Map is also different:
Device Type
Map Action
Select Action
Device Interface IP
Map the L3 neighbor of the first hop of the device.
Enter the corresponding IP.
Host Name
Enter the corresponding name.
Map the auto L3 links of all devices in the group corresponding to the virtual IP.
Enter the corresponding IP or name.
Internet Cloud
Map Internet Cloud.
MPLS Cloud
Map MPLS Cloud.
Endsystem
Map the first L2 neighbor of the device.
Unknown Endsystem
Unknown IP
Map the unknown IP.
HA Group
Map all devices in the HA group, and auto-link L3 links.
Duplicate IP
Map all devices with duplicate links.
Enter the corresponding IP. |
Path
Map the path.
Map
Open the map.
IPv6 Device Interface IP
Map the IPv6 neighbor of the first hop of the device.
