R12.1 Project-2025Sep08
Exclude and Include VNets in Discovery
This feature provides the flexibility to discover the specified virtual networks listed in the included virtual network configuration or not listed in the excluded virtual network configuration.
Information Note: The feature has been available since version IE10.1.0.
Follow the steps below to exclude and include VNets in discovery :
  1. On the Domain Management page, go to Discover tab.
  2. Select the API Server.
  3. Click Edit from the dropdown menu.
  4. In the Advanced section.
    1. Click Add to select the Excluded Virtual Networks or Included Virtual Networks key.
    2. In the Value fieldt, enter the VNet Resource IDs separated by a semicolon.
    3. Click Save.
      Information Note: Don’t use the value of Virtual network ID displayed on the Azure portal. Instead, click JSON View in the upper-right corner and use the value of Resource ID or the id key on the Resource JSON page.
      Graphical user interface, textDescription automatically generated
Select the API Server and run the discovery process. Refer to Discover Azure Networks.
