Discover Azure Networks
The following topic guides you through the process of integrating Microsoft Azure with NetBrain using API access. It covers how to set up a secure connection, discover Azure resources, and keep the data updated and enriched in your NetBrain domain.
  • Setup Azure API Access: Learn how to configure API access to Azure by setting up the required API Server and connecting it with your Azure environment.
  • Discover Azure Resources: Understand how to discover Azure network components, such as virtual networks, subnets, and virtual machines, and bring them into NetBrain for visibility and analysis.
  • Set Up Benchmark Task to Auto-Update Azure Data: Explore how to automate the update process and enrich the discovered data to reflect ongoing changes in your Azure environment.
  • Appendix: Refer to the appendix for detailed technical requirements, including NetBrain's API Server setup prerequisites and the Azure IAM permissions required for successful integration.
