Types of Parsers in Intent
On the Define Variable tab for intent diagnosis creation, you can define different parsers, which will parse different variables. Add Parser from the Config and CLI command section and define the variables via Visual Parser. Visual Parser supports five types of variable definitions: Single Variable, Table, Paragraph, Collector, and Json Table. You can also directly click Auto Pattern to define a new parser via the auto parser function. See Add-on Parser for more details.
  • Add Single Variables
  • Add Table
  • Add Paragraph
  • Add Collector
  • Add Json Table
  • Dependency
  • Merge Table
  • Append Table
  • Aggregate Table
