Applicable Features for the Select Intents Dialog
The following table describes the features where this common control can be applied.
No.FeatureDescription
1Map Intent - copy an existing NI as Map NI
  • Supported selection mode: Single selection.
  • Supported Intent Type: Common Intent, Common Map Intent, Site Map Intent, Device Group Map Intent, Path Intent, Intent Cluster.
  • Show Network Intent for Current Map Only: Supported, checked by default.
  • Show Published Intents Only: Supported.
  • Show Intents with Template Qualifications Defined Only: Supported.
2Path Intent -  copy an existing NI as Path NI
  • Show Network Intent for Current Map Only: Supported if a map is open.
  • Show Published Intents Only: Supported, unchecked by default.
3Runbook Intent Node - select intents to execute from the Intent Node of a Runbook
  • Supported selection mode: Multiple selections.
  • Show Published Intents Only: Supported, checked by default.
4
Network Change - select intents to execute from the Intent Node of Network Change
5
Guidebook - Recommended Automation
  • Supported Intent Type: Common Intent, Common Map Intent, Site Map Intent, Device Group Map Intent, Path Intent.
  • Intent Type not supported: Intent Cluster.
6Install single intent to Triggered Intent in Preventive Automation Manager
  • Show Network Intent for Current Map Only: Not supported.
7
  • Data View Template - add Recommended Automation when creating a Data View
  • Data View Template - add Drill-down Automation when creating a Data View
8
API Stub - change the Select Intent settings of the Intent node in API stub
11
NIC - Seed Intent Node
12
NIC - Member Intent Node
  • Supported selection mode: Multiple selection.
13Follow up Intent-Select Intent (Standalone)
  • Supported Intent Type: Common Intent.
  • Intent Type not supported: Common Map Intent, Site Map Intent, Device Group Map Intent, Path Intent, Intent Cluster.
14
Automation Data Table - Intent column - Select Intent
15
Intent Based Automation Center - Publish Intents
16
Schedule Automation - Schedule Intent - Add Task
17
Automation Bot Manager - Intent Node
