Add-on Parser
In auto parser, the parser pattern (single pattern or paragraph pattern) is determined automatically. In add-on parser, the parser pattern is manually selected by users first, then users continue to define the parser.
The UI components for add-on parser mode (the UI is a sample paragraph pattern) are shown below:
With the add-on parser function, you can define the following types of parser patterns.
- Single-variable parser
- Paragraph parser
- Table Parser
- Collector Parser
- JSON Table Parser
- Dependency Pattern
- Merge Table
- Append Table
- Aggregate Table
