Data Tables
In the Device Details pane, you can perform the following actions:
- View Data Tables in Device Details Pane
- Retrieve Data Tables from the Live Network
- Compare Historical Data Tables
Supported Data Tables
Data Table
IPv4 Supportability
IPv6 Supportability
1
Route Table
Yes
Only support data retrieval via CLI. |
2
ARP Table
Yes |
No
3
MAC Table
Yes
No
4
NDP Table
Yes
5
NCT Table
Yes
- In the Device Details pane, select the Data Tables tab. Only the available data tables for the target device are listed.
Select the table type you are interested in to view detailed data.
In the Device Detail pane, click
to open the pop-up window.
Click
to retrieve live configuration.
Click
to save the newly retrieved data table to the current baseline.
Click the icon
to review the original text data rather than in the table view.
Tip: To save the data table to the current baseline, close the window and open it again to enable the icon .
Click
in the Device Details pane to open the Compare window for Data Table.
- You can select data tables from different times to compare. Exporting the comparison result is also available.
