CLI Commands
In the Device Details pane, you can perform the following actions for CLI Commands:
- Browse CLI Command Outputs in Device Details Pane
- Searching Keywords in CLI Command Results
- Retrieving CLI Command Results from the Live Network
- Comparing Historical CLI Command Results
View CLI Command Outputs in Device Details Pane
- In the Device Details pane, select the CLI Commands tab. The outputs of the first CLI command saved in the Current Baseline for the target device are displayed by default.
- Select another CLI command from the drop-down list to navigate to its outputs.
Tip: The CLI command outputs saved in the Current Baseline can be customized in a scheduled benchmark task. To add more CLI commands to the device, go to the benchmark and load the CLI Template accordingly. See Benchmark Task Settings and CLI Command Template for more details.
Search Keywords in CLI Command Results
For CLI Command Results, you can search for keywords:
Normal Search: Type a keyword in the search bar, and the system will highlight all words containing the whole or partial keyword. You can use
to easily browse the next or the previous highlighted items.
Match Whole Word: Check this box to search the whole word. Type a keyword in the search bar, and the system will only highlight the words exactly matching the whole keyword. You can use
Retrieve CLI Command Results from the Live Network
In the Device Detail pane, click
to open the pop-up window.
Click
to retrieve live configuration.
Click
to save the newly retrieved data table to the current baseline.
Click
in the Device Details pane to open the Compare window for CLI Command Results.
- You can select the CLI Command Results from different times to compare.
Use
to find the next changed item. You can also export the comparison result.
Tip: You can use the Manual Tag function to help you find the data you want. When you manually add tags to data, you can filter out the data with a manual tag. |
