Create Runbook from an RBT
This chapter describes two methods for creating a runbook using a Runbook Template (RBT):
Create Runbook via RBT
Generate a complete runbook based on a selected RBT. -
Add Runbook Node via Select RBT Dialog
Insert an RBT into an existing runbook using the Add Node dialog.
