All Runbook Templates
Power users can access the Runbook Template Manager to browse all runbook templates. They can view existing templates or create new ones.
  1. Shared Runbook Templates — Contains runbook template files accessible to all users in this domain.
  2. Information Note: A default template is provided to create a runbook.
  3. My Runbook Templates — Contains runbook template files only accessible to yourself in this domain.
  4. You are allowed to perform the following actions:
    1. The number of the runbook input variables is also displayed.
    2. You can select a node to view its information at the bottom.
    3. Filter the RBT's by current map/tag.
    4. You can also perform the actions shown in the following image for RBT folder and runbook template.
