Allocate License Nodes to an Existing Tenant and Domain
- Log in to System Management Page.
Go to the Tenants tab, and then select Edit from the dropdown list of the desired existing tenant.
Allocate the maximum number of license nodes to the tenant.
Note: The user interface is different depending on your license type.
For the Separate Pool license, you need to enter the maximum units for each network module in your license, such as Foundation Nodes, Cisco ACI Ports, etc.
For the Universal Pool license, you only need to enter the maximum license nodes.
- Click OK to submit.
Allocate License Nodes to an Existing Domain
- Log in to End User Page.
- Click Domain name from the quick access toolbar and select Tenant from the drop-down menu.
Hover over the domain you wish to edit, click
and select Edit from the drop-down.
- Specify a domain name.
- Allocate a maximum number of nodes to the Domain.
For the Separate Pool license, you need to enter the Maximum units for each network module in your license, such as Foundation Nodes, Cisco ACI Ports, etc.
For Universal Pool license, you only need to enter the maximum license nodes.
- Click OK.
