Visualize AWS Network
Prerequisites
Discover your AWS network in NetworkBrain. For more details, refer to NetworkBrain Quick Setup Guide_AWS.
User Flow
The general user flow of visualizing an AWS network in NetworkBrain is as follows:
  1. Understand AWS Network Tree
  2. Calculate Path Across AWS Network
  3. Build Data View Template for AWS Network
  4. Use Runbook Automation for AWS Network
  5. Integrate with Third-party Tools for SPOG
For more details about AWS network objects that can be visualized, refer to Supported AWS Network Objects.
