View Recommended Automation in Predefined Guidebook
You can select a predefined Guidebook in the Guidebook drop-down list.
Information TIP: Mouse over the Guidebook, and the basic information such as name, ID, and description will be shown.
After a manually defined Guidebook is selected, the recommended automations belonging to this Guidebook will be displayed.
The displayed results vary with different types of Guidebook elements:
Hypothesis
#MeaningAfter Clicking
1a dummy node representing the manually defined hypothesisN/A
2the predefined noteN/A
3the instance of the respective Runbook Template, Network Intent or Network Intent ClusterRefer to: Viewing Runbook Template or network intent in Viewing Auto Qualified Recommended Automation.
Data View Template
1the manually added Data View TemplateRefer to: Viewing Data View Template in Viewing Auto Qualified Recommended Automation.
2the description defined by the user when adding Runbook Template or Network Intent to Data View Template.N/A
3the instance of the respective Runbook Template or Network IntentRefer to: Viewing Runbook Template or network intent in Viewing Auto Qualified Recommended Automation.
