Filter Recommended Automation
You can use the following types of filters to narrow down the list of the desired recommended Automation (s):
  • Type
  • Tag
  • Keyword
  • Type
    You can filter recommended automations by type.
  • If Auto-Created Guidebook is selected: It displays qualified recommended Automation. You can select from Qualified Data View Template, Qualified Runbook Template and Qualified Network Intent.
  • If a manually defined Guidebook is selected: You can select from Hypothesis and Data View Template.
  • Tag
    If tags are assigned to the Data View Template, Runbook Template, Network Intent and Network Intent Cluster, you can leverage tags to filter matched recommended Automation.
    Information Note: by default, the system selects All to display all recommended Automation (s) regardless of whether it has assigned tags.
    Keyword
    You can input keywords to match the Data View Template, Runbook Template, Network Intent, Network Intent Cluster and Hypothesis.
