OUI Information
The first 24-bit number of a MAC address is the OUI (organizationally unique identifier) that uniquely identifies a vendor. The system uses the OUI information to identify the vendors of MAC addresses displayed in an ARP table or MAC table.
Managing OUI Information
- Log in to the Tenant Management page.
- On the Tenant Management page, click
and select Misc Configuration. The OUI Information is displayed on the Misc Configuration tab. - Perform the following operations based on your needs.
Adding an OUI entry
Importing OUI information
Exporting OUI information
Click Export to export the OUI information.
