Multi-Vendor Support List (SDN)
The table below describes the SDN (including SD-WAN) device types and vendors supported in the system:
| Technology | Device Type | Supported Level | Discovered via | ||
| Tier 1 | Tier 2 | Tier 3 | |||
| SDN-WAN | CloudGenix ION SD-WAN | √ | √ | CLI/API | |
| VeloCloud Edge | √ | √ | SNMP/CLI | ||
| VeloCloud Gateway | √ | √ | SNMP/CLI | ||
| VeloCloud Orchestrator | √ | SNMP | |||
| Versa Analytics | √ | √ | CLI | ||
| Versa Controller | √ | √ | API | ||
| Versa Director | √ | √ | CLI | ||
| Versa FlexVNF | √ | √ | API | ||
| Viptela vBond | √ | √ | API | ||
| Viptela vEdge | √ | √ | SNMP/CLI | ||
| Viptela vManage | √ | √ | API | ||
| Viptela vSmart | √ | √ | API | ||
| Cisco Meraki Z3 | √ | API | |||
| Cisco MX | √ | API | |||
| Aryaka router | √ | √ | SNMP | ||
| Cisco ACI | Cisco ACI APIC | √ | √ | API | |
| Cisco ACI Leaf Switch | √ | √ | API | ||
| Cisco ACI Spine Switch | √ | √ | API | ||
| EXSi | VM Host | √ | √ | API | |
| vSphere Distributed Switch | √ | √ | API | ||
| vSphere Standard Switch | √ | √ | API | ||
| VM NSX-V (for vSphere) | NSX Manager | √ | √ | API | |
| NSX Controller | √ | √ | API | ||
| NSX Logical Switch | √ | √ | API | ||
| NSX Edge Security Gateway | √ | √ | API | ||
| NSX Distributed Logical Router | √ | √ | API | ||
| AVI | AVI Controller | √ | API | ||
| AVI Service Engine | √ | API | |||
| Big Switch | Big Switch Controller | √ | √ | SNMP/CLI/API | |
| Big Switch Spine Switch | √ | API | |||
| Big Switch Leaf Switch | √ | API | |||
The limitations of SDN support include the following:
- Cisco ACI
- Remote Leaf is not supported.
- Cannot map out EoMPLS devices between Transit Leaf and Spine for Stretched Fabric deployment that uses EoMPLS to interconnect Transit Leaf and Spine.
- Running Qapps on logic nodes (like Tenant, VRF, EPG, etc.) is not supported.
- NSX-V
- Overlay L2 topology and underlay paths are not supported.
- Big Switch
- Only support spine/leaf switches' L2 link(NDP) table. Other data is retrieved from the controller as NCT tables.
- Cisco Meraki Z3 and MX
- SD-WAN routing table is populated by NetworkBrain's algorithm but not exported by API.
- The netmask of some interfaces cannot be accurately retrieved by API. However, the netmask of the VLAN interface can be retrieved by API.
