View GCP Object Configurations
Basic configuration file is a critical data source to understand the basic configuration and specification of different devices/nodes. It includes one or more APIs data and is also a useful and important way for Public Cloud management and maintenance.
Note: The feature has been available since version IE10.1.7. |
Feature Scope
- GCP
- Google Cloud VPC Router
- Google Cloud Firewall
- Google Cloud VPN Gateway
- Google Cloud Router
- Google Cloud Partner Interconnect
- Google Cloud Dedicated Interconnect
- Google Cloud Load Balancer
- Google Cloud NAT Gateway
- Google Cloud Internet Gateway
- Google Cloud Private Service Endpoint
Feature Usage
Right-click the device/node on the map, select View Configuration File to open the configuration file. The feature provides compare
, live retrieve
or export
functions by clicking the dedicated icon.
The configuration file can be used for:
- Public Cloud management and maintenance if you need to analyze or monitor the basic key configuration or specifications of the device/node.
- Automation flow to monitor the system health status or troubleshooting procedure.
