Integrate with Third-party Tools for SPOG
The capability to visualize data from 3rd-party cloud management tools enables NetworkBrain dynamic map to render a complete view of your GCP infrastructure. The integration with 3rd-party cloud management tools is highly customizable, which means NetworkBrain can be integrated with any cloud management tools to suit your specific needs. For more details, refer to SPOG.
The built-in Data View Template for GCP collects and analyzes the GCP firewall rule logs from Datadog and displays the results on the dynamic map. This integration can help you find the history of a firewall rule and trace down any mistakenly deleted firewall rules.
