Dynamic Search
Dynamic search allows you to build complex search queries by using multiple search criteria.
Take the following features for example:
Dynamic Search in Site Manager
Example: Search dynamically when adding a container site or adding a leaf site.
  1. Set search criteria and boolean expression for devices. See step 3~5 in Search Devices by Formula for more details.
  2. Click Search. The devices matching your search conditions are listed.
    Note: You can now include SDN and Public Cloud devices in the Site using both Dynamic Search and manual methods.
    Note: You can use the new API Server search criteria to make it easy to add SDN and Public Cloud devices to your Site.
Tip: If the search result contains the devices that you don't want to add to the site, right-click them separately and select Exclude. Or you can exclude devices in bulk, click Exclude Devices. To manually add other devices to the site, click Add Devices Manually.
Dynamic Search in Device Group
Example: Search devices dynamically when creating a Device Group or editing an existing one.
  1. Set device scope, search criteria and Boolean expression for devices. See step 2~5 in Search Devices by Formula for more details.
  2. Click Search. The devices matching your search conditions are listed in the search result.
    TableDescription automatically generated
  3. Click OK.
Dynamic Search in Inventory Report
Example: Search devices dynamically when customizing inventory report.
  1. Define one criterion or multiple criteria to filter devices. As soon as a criterion is added, the Boolean expression becomes A and B, A and B and C and so on. You can manually change and to or if required.
    Graphical user interface, tableDescription automatically generated
  1. Click OK.
