Device Group Pane
To view the device group functionalities and features, open any of the device group as follows:
  1. Click the start menu  and select Device Group to open the Device Group Pane.
    Note: You can search within subfolders or device groups. Double-clicking an item in the search results locates it in the left pane.
  1. Key operations available for the Device Group Folders.
Information NoteSystem Device Groups and Media are system-generated device groups that cannot be modified by end users.
  • Create a New Folde.
  • ​​Create a New Device Group. For more information, see Create a Device Group.
  • Rename a Device Group Folder.
  • Move the selected folder to another folder.
Information Note: This operation is unavailable for folders System Device Groups (if any) and Media (if any). For Policy Device Group, folders in this category cannot be moved to other categories, like Shared Device Groups or My Device Groups, but can be moved to another folder inside this category.
  • Delete selected folder:
  1. Key operations for Device Groups.
    • Edit selected Device group.
Information Tip: To edit the device group, see Create a Device Group for more infromation.
Information Note: This operation is unavailable for device groups in System Device Groups and Media.
  1. Move selected Device Group to another folder
Information Note: This operation is unavailable for device groups in System Device Groups (if any) and Media (if any). For Policy Device Group, device groups in this category cannot be moved to other categories, like Shared Device Groups or My Device Groups, but can be moved to another folder inside this category.
