Delete Sites
You can delete empty container sites (which do not contain leaf sites) or clear all sites in your domain.
Note: If you delete a container site, all its leaf sites will be deleted. |
Deleting Empty Container Sites
- Log in to the Domain Management page and click Site on the Start Page to open Site Manager.
In the Site Manager, right-click the My Network node in the site tree and select Remove Site without Leaf Site from the drop-down menu.
Clearing All Sites
In the Site Manager, right-click the My Network node in the site tree and select Clear All Sites from the drop-down menu.
Note: Please be careful of this function because Sites cannot be recovered. We recommend you to backup your sites before clearing them all just in case you need to restore them.
