Export Sites
You can export your site hierarchy alone with site members to a .csv or .xlsx file.
- Log in to the Domain Management page and click Site on the Start Page to open Site Manager.
- In the Site Manager, right-click the My Network node in the site tree and select Export to Spreadsheet from the menu.
- Specify the file format (.csv or .xlsx).
- Select the devices that you want to include for each leaf site in the exported file. You can export all devices or the top 5 devices in each leaf site by selecting Export 5 Site Members.
Tip: During the export process, the manually added devices have a higher priority than the dynamically searched device. - Click Generate. The .csv or .xlsx file will be downloaded to your PC automatically.
