Define the Basic Settings
In the full editor follow the steps below, you can create a new chatbot and define its
Description
  1. Click  .
  2. In the Edit Chatbot window, enter the description.
  3. Click OK.
Greeting Message
  1. Click the start node, and define the greeting message.
Login Page
  1. Click the empty area within the Canvas.
  2. On the Login Screen tab, you can define the login page where end users will input their credentials before using the bot.
    1. Upload the logo.
    2. Define the headline.
      Example Image: Welcome to NetworkBrain Chatbot.
      What end users will see:
About Bot
The About Bot page will be loaded after end users log in.
  1. On the About Bot tab, turn on the toggle to enable the About Bot page.
  2. Upload the logo.
  3. Enter the description for the chatbot, introducing its purpose. Sample Image:
