Basic Operations on Canvas
After Bot UI Settings are defined, you can start to define the automation flow on the canvas.
OperationsToolbar
Undo/Redo
Delete a nodeSelect and press the “Delete” button on the keyboard
Link two nodesDrag the line from node 1 to node 2.
Edit the bot name and description
Exist the Edit mode and return to the bot manager.
Display the flowchart fully and proportionally
Zoom in/out the flowchart
Show/hide the left pane
Show/hide the right pane
Change the node name shown on the canvas
For the intent node, intent template node, automation data table node, and prompt node, double-click the node and enter the name.
Change the link name shown on the canvas
Double-click the link and enter the text.
