Create a Dashboard
The Dashboard visually displays multiple reports in different charts for a specific purpose.
Through Dashboard, you can have an effective method to tell what happens in the network. For example, whether Boston office’s network has a problem, or whether all WAN links across the entire network are running well. With the key metric trends of the network displayed, you can also perform trend analysis.
Main User Flow
  1. Select a Report
  2. Define Chart
  3. Define Call-out
  4. Repeat step 1-3 to add more widgets, and adjust the layout of the widgets
  5. Save Dashboard
