Manage Dashboard
In the Dashboard Manager, you can view and manage all the dashboards.
Click the start menu , and select Intent-Based Automation > Universal Dashboard (alternatively, you can directly click from the Taskbar to open Dashboard Manager).​
  • Select the desired dashboard, click   and you can:
    • Open the dashboard
    • Move the dashboard to another folder
    • Save as
    • Rename the dashboard
    • Delete the dashboard
    • Export the dashboard to a local folder
  • Select the desired folder, click  and you can:
    • Create a subfolder
    • Create a new dashboard within the folder
    • Rename the folder
    • Delete the folder
    • Import one or more dashboards into this folder
