View Azure Object Configurations
    Basic configuration file is a critical data source to understand the basic configuration and specification of different devices/nodes. It includes one or more APIs data and is also a useful and important way for Public Cloud management and maintenance.
    Information Note: The feature has been available since version IE10.1.7.
    Feature Scope
    • AWS
      • AWS VPC Router
      • AWS VPC Endpoint (Type: Gateway/ Interface/GatewayLoadBalancer)
      • AWS Transit Gateway
      • AWS Internet Gateway
      • AWS ELB(ALB/NLB)
      • AWS NAT Gateway
      • AWS Gateway Endpoint
      • AWS Firewall
    • Azure
      • Azure VNet Router
      • Azure Virtual Network Gateway (VNet, Type: VPN/ExpressRoute)
      • Azure Load Balancer
      • Azure NAT Gateway
      • Azure Firewall
      • Azure MSEE
      • Azure vHub
      • Azure VPN Gateway (vHub)
      • Azure Express Route Gateway (vHub)
      • Azure Application Gateway
      • Azure Private Link End Point
    • GCP
      • Google Cloud VPC Router
      • Google Cloud Firewall
      • Google Cloud VPN Gateway
      • Google Cloud Router
      • Google Cloud Partner Interconnect
      • Google Cloud Dedicated Interconnect
      • Google Cloud Load Balancer
      • Google Cloud NAT Gateway
      • Google Cloud Internet Gateway
      • Google Cloud Private Service Endpoint
    Feature Usage
    Right-click the device/node on the map, select View Configuration File to open the configuration file. The feature provides compare , live retrieve or export functions by clicking the dedicated icon.
    The configuration file can be used for:
    • Public Cloud management and maintenance if you need to analyze or monitor the basic key configuration or specifications of the device/node.
    • Automation flow to monitor the system health status or troubleshooting procedure.
    Graphical user interface, text, application, emailDescription automatically generated
