Azure VM Scale Sets Support
Azure Virtual Machine Scale Sets (VMSS) allow you to create and manage a group of Load Balanced VMs. It includes visibility of the basic node like VMSS instance and topology between VMSS instance and Virtual Network and Load Balancer.
Note: The feature has been available since version IE10.1.7. |
Feature Scope
- Azure
- Azure VM Scale Sets (VMSS)
- Azure VM Scale Sets Instance (VMSS Instance)
- Network Tree
- Node/Topology on Map
- Device/Node Details
- Context Map
- Data View Template (DVT)
- Data Table (NCT)
- Path
Feature Usage
- Locate the Virtual Machine Scale Sets (VMSS) from Network Tree. The Network Tree clearly shows the resource hierarchy relationship for VMSS and VMSS instance inside a Tenant /Subscription/Virtual Network level.
- Browse the node and topology on the map.
- Check device/node and interface details.
- Path shows up the end-to-end traffic flow, which is critical to diagnose the network reachability or service availability hop by hop with key information like route and security check details.
