Map Data View Manager
Map Data View Manager is used to centralize and manage all map data views saved within a map page.
Browse Map Data Views
- After applying a map data view to a map, move the mouse to the following area and click the
icon to open the Map Data View Manager page.
- Click a map data view group in the left pane, and all included devices are listed under the Details tab. By default, the value of each data unit of a device is displayed on its position. You can click Show Properties to only show the data unit name. See Browsing Static Data Views in Data View Manager for more details.
- Select a data view in the left pane and click the Updated Records tab to view the updated records of the data view.
Delete a Map Data View
To delete a map data view, right-click it in the left pane and select Delete from the drop-down menu. See Deleting a Static Data View for more details.
Delete a Map Data View from Map
Map data views can be deleted not only from a map, but also in the Map Data View Manager.
Tip: To delete the target data views in Map Data View Manager, see Deleting a Map Data View for more details. |
- In the Data View pane, click Static.
- Click the target map data view to apply it to the map page.
- Click
to delete the data view.
