Discover Cisco ACI Networks
The main flow of discovering Cisco ACI networks are as follows:
- Set Up APIC Server Access for NetBrain — double-check the configurations on your APIC server from which you can read data.
- Set Up API Server in NetBrain — define the required parameters to access 3rd-party systems via APIs.
- Discover ACI Data in NetBrain — discover the network data model in a NetBrain domain.
- Auto-Update ACI Data in NetBrain through Benchmark — execute a benchmark task to retrieve all data and build all components, including visual spaces and data views.
