Define Replication Logic
The system shows key replication logics under the Replication Logic tab in the intent editor. This tab displays all configurations related to intent replication, enable the Serve as Template for: switch and you will access to define Intent Qualification, Macro Variable for Seed Command, Critical Variable, and for more additional settings in Full Settings for Template dialog. You can easily find the settings related to intent replication and understand the key steps to configure an intent as template.
You can also install the replication by wizard.
