The system provides APIs for users to integrate with their third-party systems to call Qmap and Runbook functions to achieve an API-triggered diagnosis, such as mapping problem devices and then collecting the live network data when alerts are generated in the third-party systems.
System Automation Manager is designed to define API tasks, that is, when a third-party system integrated with NetBrain API services generates alerts, what actions will be triggered in the system.
Click the start menu
, select System Automation Manager. The System Automation Manager opens on a new page with two tabs displayed:
▪API Triggered Tasks — contains all API call task instances and relevant information from the integrated third-party systems. The system generates an API task instance for every incoming API call.
▪API Stub Manager — used to create API tasks so that a third-party system can call NetBrain APIs and trigger relevant tasks, such as mapping devices and collecting device data when alerts occur. Once an API task is created, it will be displayed on the API Stub Manager tab.
▪Integrating with Third-Party APIs
