The following table lists the information about a triggered API task.
Column Name |
Task ID |
When the system receives an API call to trigger a task, it will generate a unique task ID to mark the API task instance. |
Task Name |
The API stub name of an API Service Stub. A third-party system relies on the API Stub Name to recognize the API tasks in the system. See Adding API tasks for details. |
Status |
The status of an API task. An API task can have the following types of status: ▪Pending — the task is in the queue. ▪Running — the task is running. ▪Finished — the task is finished. ▪Forced Stop — the task exceeds the specified Maximum Execution Time and is forced to stop. ▪Manually Stop — the task is manually stopped. ▪Failed — the task failed to run. Point to the failed icon to display the failure log. |
Triggered By |
The system that triggers the API task. |
Triggered Time |
The time when the API task is triggered. |
Start Time |
The time when the API task starts to run. |
End Time |
The time when the API task is ended. |
Mode |
The mode of the API task defined in API Service Stub. See adding API tasks for details. |
Map |
Opened or generated map defined in API Service Stub. Click it to open the specific map page. |
Last Access By |
The User ID that last visits the map. |
Script |
The script that defines how to call an API task in a third-party API system. The script will be generated once an API task is created in the API Stub Manager. Click it to view the script in the pop-up dialog. You can also copy the script and paste to your third-party system. |
