The following table lists the attributes of an API stub.
Column Name |
Stub Name |
The task name of an API Service Stub. Third-party systems rely on the name to recognize API tasks in the system. |
Script |
The script that defines how to call an API task in a third-party API system. The script will be generated once an API task is created in the API Stub Manager. Click it to view the script in the pop-up dialog. You can also copy the script and paste to your third-party system. |
Enabled |
An API task is enabled by default. You can disable or enable the API task under this column. |
Mode |
The mode of an API task. |
The description of an API task. |
Map Creation |
The way of an API task to create a map. |
Runbook Triggered |
Whether an API task includes a runbook. |
Author |
The author of an API task. |
Reference Count |
How many task instances have called an API task. |
Last Modified |
The time when an API task is last modified. |
▪Adding API Tasks in API Stub Manager
